I suppose I should mention the bottom end has an Eagle crank, Eagle rods, and Ross pistons
The only RPM-related concern might be the oiling system, but the upgrades done to it w/ the last build were targeted at better oil control at high(er) RPM
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
