Not trying to be a butthead, but there is absolutely ZERO reason to use a Mr Six Pack cam in ANYTHING unless you are trying to pass Pure Stock tear down tech…the clown won’t even give specs for it and there are literally TONS of better cams out there…I don’t understand why anyone would buy one?? 🙄🤦♂️ He’s NOT a camshaft guru…he’s just taken ONE combination and tried a few different grinds that all have the same lift and found one that works good for that combo…by running his magic cam 😂 all anyone is doing is limiting how good their motor will run…🤦♂️
