your quench is fine. why do you think the engine is under performing.
couple of things to look at...
1. ignition timing, where is it set?
2. headers too large
3. air fuel ratio? have you had this checked?
4. what springs in the secondaries?
5. what advance springs in the distributor
I have never heard anybody at the dragstrip worry about quench. Jerry above here has some great points.
Never heard the OP mention a dragstrip. In fact, when replying to the cam specs he said street car.
I thought some things at the strip would apply to the street. But, I may have missed it, but timing being critical, was the dampener mark checked to TDC?
