i dont think it detonation issues, what hyd lifters did you put on the voodoo cam? those cam have wierd base circles only there lifters have cups in right spot, for there cams. i think your valves are not closing all the way @ high rpms, wrong lifters or you need adj rockers for your setup. try rockers first
