Originally Posted by Twostick
Any suggestions on what rod to Weld with for this application?
Kevin
With the way the head of the ALLEN bolt is bent I can't think of any JB Weld that would ever be strong enough. Looks to me welding might(???) work but replacing the part and bolt is the only solution IMO.
If you want to try JB Weld, as you asked, the original long cure JB Weld epoxy is (according to JB Weld) is the strongest when finally cured.
https://www.jbweld.com/our-videos
