Has anybody thats running adjustable strut rods welded in support washers on the k member for the strut rods? I remember reading somewhere that someone said you can't reinforce the k member around the holes for the rods if you're running adjustable strut rods, but I can't seem to find the article. I'm looking to strengthen the k member and I've already welded in my own braces for the steering box mount and lower control arms. I just don't want to weld in the supports for the strut rods and run into a problem later when I'm trying to install them.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
