Originally Posted by mgoblue9798
Unless you are running a lockup style 727, you need to consider what your cruise rpm will be v/s the converter rpm. If cruise is lower than the converter it might be a problem. You would need to discuss it with your converter manufacturer.
true i have a cheap hughs 2400 converter i assume that it "should" be ok for me i like fti and pro torque myself
i
if You Like Gremlinsteve. Gremlinsteve Likes You.
