Thanks for all the replies. The bolt replacement kit didn't have instructions on it. The seal looked good, so I just got bolts. I decided to get the kit with the bowl/tank seal this time. Figured I didn't want to reuse the rubber washers from the incorrect install. I noticed the package had instructions on it and they matched what was said here. Funny, the bolt set up that came off was not the same as the instructions said. Tank is back on and no leaks. I know it may be a stupid question to some, but I really appreciate the knowledge on the board.
