so you have to tighten to crush the seal between the bowl and tank.
but not enough to crack the porceline.
if you press down on the tank, how much more give is there to the bowl is what I look for.
that gives you an idea of how much more you can tighten.
I mean don't lean 200 pounds on it, but push down and see how much give you get.
