Looks like the wipe is a hair below the crown and not rolling off the crown, and a hair above the root (root would be bad). It also appears it's not rolling off the toe (which would be OK), but is rolling off the heel (which is OK). Technically I'm not sure the pattern gets any better than that with lots of conatct area and no crown or root issues. Yep, run it.
