Re: Quest for 1000 hp, slow going!
[Re: Bad340fish]
#3035074
04/19/22 03:56 PM
04/19/22 03:56 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Is the terminator EFI the throttle body system or port EFI? If it is a throttle body system do you have a carb to compare with it?
I hope you get your numbers! thanks! The injection is constant flow mechanical. No electronics involved. This type of injection is dirt symple, pretty much. The pump is engine driven at camshaft speed, and pumps twice what the motor needs. Eight hoses to nozzles of . 038 size, and a nineth hose with a pill of . 080 to dump off the excess fuel. A tenth hose is set up to open at above peak torque as pressure rises, pushing through a spring loaded poppet valve with a small pill sized to keep the afr in range.
Entire Thread
gregsdart
04/19/22 03:00 PM
Bad340fish
04/19/22 04:18 PM
gregsdart
04/19/22 07:56 PM
440Jim
04/19/22 04:20 PM
Bad340fish
04/19/22 07:38 PM
gregsdart
04/19/22 08:12 PM
B3422W5
04/19/22 08:27 PM
gregsdart
04/19/22 11:43 PM
Guitar Jones
04/20/22 12:29 AM
gregsdart
04/20/22 02:38 AM
B3422W5
04/20/22 03:01 AM
kwikblownhemi
04/20/22 02:28 PM
AndyF
04/19/22 07:26 PM
merpar
04/20/22 02:42 PM
Al_Alguire
04/20/22 05:03 PM
gregsdart
04/21/22 11:49 AM
FastmOp
04/21/22 03:37 PM
Al_Alguire
04/21/22 05:40 PM
gregsdart
04/21/22 11:20 PM
gregsdart
04/21/22 11:31 PM
Cab_Burge
04/22/22 03:31 AM
HardcoreB
04/22/22 01:50 PM
gregsdart
04/23/22 05:14 AM
Re: Quest for 1000 hp, slow going! Update!
gregsdart
08/26/22 11:58 PM
gregsdart
08/27/22 01:14 PM
Thelma133
08/27/22 08:08 PM
gregsdart
08/27/22 09:42 PM
Thelma133
08/28/22 03:11 AM
gregsdart
08/29/22 02:49 AM
Thelma133
08/29/22 07:32 AM
Cab_Burge
08/29/22 03:27 AM
RATTRAP
08/29/22 11:38 AM
gregsdart
08/29/22 03:41 PM
EvilB1Dart
08/29/22 04:04 PM
67CudaRacer
08/31/22 04:19 PM
gregsdart
09/01/22 02:09 PM
67CudaRacer
09/02/22 12:25 PM
Cab_Burge
09/01/22 03:12 PM
gregsdart
09/01/22 03:52 PM
Cab_Burge
09/01/22 06:24 PM
justinp61
09/01/22 10:09 PM
gregsdart
09/01/22 11:52 PM
67CudaRacer
09/02/22 12:39 PM
gregsdart
11/17/22 09:39 PM
JERICOGTX
11/18/22 10:50 AM
Gabby63
11/18/22 02:49 PM
EvilB1Dart
11/18/22 04:44 PM
Tig
11/19/22 12:30 PM
gregsdart
11/21/22 01:42 AM
HardcoreB
11/21/22 04:04 PM
440Jim
11/21/22 06:26 PM
gregsdart
12/09/22 02:54 AM
Cab_Burge
12/09/22 03:22 AM
gregsdart
12/10/22 01:54 AM
gregsdart
12/21/22 03:57 AM
440Jim
12/21/22 04:03 PM
440Jim
12/22/22 06:08 PM
gregsdart
12/23/22 02:25 AM
440Jim
12/23/22 06:20 PM
gregsdart
12/23/22 09:41 PM
gregsdart
12/24/22 01:35 AM
Al_Alguire
12/24/22 07:08 AM
440Jim
12/24/22 02:02 PM
'72CudaRacer
12/24/22 03:16 PM
moparx
12/24/22 06:55 PM
Cab_Burge
12/24/22 07:13 PM
gregsdart
12/25/22 08:27 AM
440Jim
12/25/22 01:55 PM
gregsdart
12/28/22 09:46 PM
gregsdart
12/23/22 01:43 PM
Al_Alguire
12/23/22 05:24 PM
gregsdart
12/23/22 06:56 PM
fast68plymouth
12/22/22 05:35 PM
Gabby63
11/21/22 05:34 PM
440Jim
11/18/22 05:42 PM
gregsdart
11/18/22 10:46 PM
