Hi sorry if this has been asked before. But I will be building my first gen3 hemi stroker motor. The stroker kit is a k1 crank and Rod kit with wisco pistions. The kit came from CNC motor sports. The info says it will have 11.1 compression with my Eagle heads. I have not bought the cam yet. But will have over 600 lift. Intake will be a ported Ritter intake. For now a holley 800 DP carburetor. I have to build them first, but headers will be 2 inch tube 3.5 collectors. I was really wanting to build a 14.1 compression stroker 5.7. But every body around me wants 1000-1500 for a early 5.7 hemi that needs rebuilt. I am buying the stroker kit and a machined block ready to build for $2500. This engine will be going in my race 91/96 Dakota sport race truck. Which has a 904 transmission with a 8 inch 5500 stall coan converter. Rearend is a 8.8 ford with 4.30 gears and MT 28.5x10.5 pro bracket radial tire. My goal is to run 10 flat to mid 9 in the 1/4. Which i don't know if thsts doable or not
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
