I pulled a 46RE out of a 2001 van this weekend, it had a spring on the pressure lever that went up to a small bracket where the shifter pivot rod bolts to the transmission. I looked at an old 727 in the garage and noticed the lever had the same hole in it that the spring was attached to.
For what ever it is worth.
