I run a 105 amp alternator, with a voltage sense wire going to my main power point. Coil on plug full EFI, One fan(used to be two until recently) electric water pump, two electric fuel pumps. I run a single yellow top optima battery. I drive my car to and from the track, I have made as many as 12 passes in a day having to cool between rounds and never had a worry.
