Hey guys , I plan on trying to make some rounds this year and have been battling the dragging starter once up to temp for a long time. If I am going to run back to back what would you suggest ? I have a small mini starter that works fine plus heavy gauge rear battery wiring and a huge Mercedes battery with 1000 cold cranking amps . The car still hates to start once its warm. My question is should I go dual heavy batteries or go with the expensive 16 Volt battery , alternator and new charger ? I hate both options but how about your opinions before I do it.
