It was over the phone with service after I gave them the code scan.
Thank you
Now for an update, yesterday I was out on a back country road on my way home from Lowes. I decided to try out the abs as it was raining & wouldn't flat spot the tires too badly. I braked hard enough to activate the ABS 2 times in a half mile, after the second time the service brake light lite up, went home & code scanned it with same results as before C2200-49. Called a friend in PA thats a parts manager at Hillview CPD in Greensburg, he ran my module #5163230A75C which superseded to 68295368AC. There are 2 in the USA & the dealerships will not sell them. No expected availability until 3-2022. I go out to part the truck & guess what ABS light is out on restart & no I didn't clear the codes?? [censored]?
I have 5 Charger popo cars parked at the shop with varing electronic failures: TCM. ABS, ABS wheel sensors, etc. I'm tired of this new improved crap. Give me a 76 3/4 ton Power Wagon with Nice big pipe bumpers & a huge tow hitch. LOL Sadly my 16 ram has been hit 3 times in 3 years coming home from work. None my fault!
As a side note I was almost killed by the ABS on my 12 street glide when the ABS failed. The ABS failure resulted in total brake loss, its a design flaw in 08 & newer Harleys that the company knows about but will not address as there have been people killed by this. I hit a car but got thrown off of the bike an was able to run with it literally up against a jersey barrier, only a small amount of road rash & bruises Harleys fix is that you have to bring your bike in every 2 years for a bleed & flush of the brake system with ABS activation. A bandage at best.
