Unless you have a compelling reason not to - Stock Eliminator, Mopar street car, purist, budget - 9" is always the right answer for a race car.
Gear selection, all steel housing, easier to work on, aftermarket support, lightweight parts, stronger when properly done, pinion lower in the carrier, etc.
If the results don't match the theory, change the theory.
