Re: How to replace shift shaft seal on 727 trans?
[Re: John_Kunkel]
#29484
09/04/06 04:20 PM
09/04/06 04:20 PM
And the "band-aid fix" is to fill the trans with a couple quarts less.
Not a good idea. The TF, unlike the engine, can suck air if the VB-to-case mating surface is exposed to the air.
I have always wondered about that....but if that was a major "issue" - why wouldn't the OEM have put some O-rings or a gasket in there?
