The problem isn't that the cars are running out of juice because there isn't enough potentially available - it's that the un(der)controlled regenerative braking can create so much battery charging that the batteries get too hot and cannot be recharged and conk out. This will be a remote software fix and should be done soon. Clearly, the bench and real-world testing did not cover this scenario. We learn as we go.
