If you wish for a high output ignition then you can run a point-type distributor with an MSD module like a 6A or 6AL and high output coil like the HVC or blaster. Connect the dizzy wire to the white wire at the module. This should give you the clean, smooth idle that electronic ignition delivers without purchasing another distributor.
