My uncle has a 'Dakota Digital' Digital dash in his 66 Chevelle, and it looks sweet! It has all the gauges needed, and the computer can be set at the push of a button for different gears and tire sizes. It also has 1/4 mile measurement/estimates as well as distance to empty for the fuel. Has the adjustable dimmer for the lights and all the dummy warning lights, turn signal indicators, the whole nine yards....
What do you guys think of one of those for a '74 Duster? It's actually cheaper than purchasing all the same gauges from Autometer. Plus it looks pretty professional when installled.
Problem is, the company doesn't make one for the Duster (or any other Mopar as far as i can tell) but the 3"x13" universal 5 gauge will fit perfectly with a little custom trim holding it in.
Here is the link:
http://www.dakotadigital.com/index.cfm/p...prod/prd217.htm
I guess I just want to know if any of you have installed one or if you would....
Thanks for the help!
Leaving Iraq and will be stateside in 8 days!!
It ain't illegal unless you get caught!
