Most of these replies are hard to read. The majority are reflective of old man taste buds and a dash complacency. . Indeed, the Franks "not red hot at all" sauce thread I think was intended to make these old farts sound tough. lol. Mo' Farts would be shut down for a good day of bathroom attendance if any of these chili recipes had any real heat to them. Well ya know with any luck you'll be an old fart too someday, but if you are the same in real life as you are here I'd be amazed if someone doesn't put you in an early grave.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
