I'd rather hear it from experience than a Hot Rod article up
You’re in luck. I guess you skipped right past csk’s post where he said:
Quote
That is the way mine is set up now. I am .020 off the bottom with Morel Hydro;s my pushrods are Ball,ball
Running them like that is more common than you think.
Nonetheless, I’m a firm believer in doing what works for you....... so if you don’t have any luck running that way...... stick with what you’re having success with.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
