Good question. Hook a pressure sending unit up to your data logger and see what the numbers are. Personally I don't trust a pan evac system to do much of anything. If the engine had a vacuum pump then I'd go with a metric ring pack. We've used the Mahle 1/1/3 mm ring packs and they free up some power that is for sure.
