Quote: Okay, here are all the numbers: Goodyear G78-15 DOT seems to be CUO 038 M87 Stamped between the stud holes M87 and 9 to the left of the stem and an 8 to the right of the stem. 369917 stamped in the rim above the stem.
I was told it was out of a mid 70's volare or aspen.
The 250 wheel with a F78-14 GOODYEAR tire was used on the Aspen/Volare. What you have was used on the B Body. Cordoba, Magnum, Charger etc...
What I have = Worthless
Gonna make the call this morning and see if I can get my $ back. Wish me luck.
