You have a large problem. The spare is probably for a GM or Ford product. Does the wheel bolt up to your car?
Goodyear G78-15 - Should be F78-14
DOT seems to be CUO 038
M87 Stamped between the stud holes - 1977 wheel
M87 and 9 to the left of the stem and an 8 to the right of the stem. - Sept 8, 1977 build date
369917 stamped in the rim above the stem. Probably a GM part number.
Now I am ticked off! I can't EVER get a break but this was my error and should have known this stuff before I bought it. This guy is a BIG mopar guy and I took his word for it. I obviously didn't try to put it on the car and could easily check the bolt circle. I'll do that in a little bit. I am sure it'll be 4 3/4 probably.. LOL
Gonna make a phone call in the morning!
Okay you were right, the part number was 3699117 and there is a chrysler insignia to the right of the 8 on the rim so it is chrysler and does appear to be 4.5" bolt circle I believe.
