I also use the LC-1. If you already have a laptop, then it kit is only $200. If you want to permanently mount a guage, thats like $80 more.
I feel the laptop solution that I use works great. You start the software, and it captures the a/f ratio as you are driving. Then you can tell which circuit on the carb needs calibration.
