383/432 Stroker that I built four years ago - Zero drips - Street motor - Factory PCV and Three Nipple Breather 1971
I also use the Mancini Billet - Brown Viton Seal - Second motor that I built with great results
Seal clocked at 6 and 12 for me anyways helped align the retainer using those alignment studs
O rings on side of retainer with a little Permatex Black RTV
If I was buying today
I would probably look at Hughes Engines Retainer Kit - They have a pressure relief area built into the retainer like the factory unit
