Moparts Main Index
| READ -
Info & Help Page
Moparts Sponsors
Tech Archive
Register
Log In
Moparts
Forums
Unlawfl's Race & Engine Tech
426 Hemi oil pressure flutter at mid rpm
Forums
Calendar
Active Threads
Search
Forum Help
Re: 426 Hemi oil pressure flutter at mid rpm
Re: dvw
#2819363
09/10/20
03:24 PM
09/10/20
03:24 PM
Mar 2011
Michigan
A727Tflite
A727Tflite
Mar 2011
Michigan
On a fresh engine build you will use up oil to fill the passages, fill the lifter valley, some oil in the heads, etc.
Once the motor was warmed up you should have drained the pan to see how much “drainable” oil you had.
If this particular pan calls for 6 quarts you should have drained 6.
Start at ground zero. Drain the pan and add 6 quarts and see if your issue is resolved. Leave the filter in place.
Work from there.
Entire Thread
Subject
Posted By
Posted
dragon slayer
09/09/20
02:14 PM
dvw
09/09/20
03:28 PM
DoubleD
09/09/20
03:55 PM
MR_P_BODY
09/09/20
04:05 PM
Cab_Burge
09/09/20
04:10 PM
dragon slayer
09/09/20
04:26 PM
Cab_Burge
09/09/20
04:38 PM
Dragula
09/09/20
05:23 PM
hemicar1971
09/09/20
07:36 PM
Dragula
09/09/20
08:01 PM
Cab_Burge
09/09/20
08:04 PM
INTMD8
09/09/20
08:09 PM
Cab_Burge
09/09/20
08:25 PM
Dragula
09/09/20
08:18 PM
ZIPPY
09/09/20
10:29 PM
dragon slayer
09/10/20
01:02 PM
CSK
09/10/20
03:20 PM
dvw
09/10/20
05:30 PM
A727Tflite
09/10/20
07:24 PM
dragon slayer
09/12/20
01:28 PM
ZIPPY
09/12/20
02:31 PM
second 70
09/12/20
03:01 PM
Cab_Burge
09/12/20
08:56 PM
dvw
09/12/20
11:09 PM
6PakBee
09/12/20
02:33 PM
Moderated by
Al_Alguire
Hotwheelsjr
moparts
not_a_charger
RangerDan440
tboomer
Hop To
Moparts Question and Answer ------
Gen III Hemi Tech
Moparts Restoration & A12 Forum
Corners Are Best - Handling Tech
Sandy's Truck Shop
Street Rodders
Stu Harmon General Forum
Moparts Extras ------
Mopar Connection Magazine
Moparts Hot Deals & New Products
Moparts Show Listings
Member Projects & Survivor Pictures
Best of Moparts / Tech Archive
Lost & Found, Clubs, Businesses, Jobs
Transport Services Wanted/Offered
Moparts Free On-Line Swap Meet ------
Ebay / Craigslist / Marketplace / WIW
Moparts A Body
Moparts B Body
Moparts E Body
Moparts Full Size
Modern Moparts Muscle
Moparts Truck / Vans / Jeep / Willys
All Other Moparts / AMC
Classic/Streetrods/Hotrods - 1961 and Before
Moparts Race Cars / Parts/Tools/Trailers
Moparts Engines
Trade/Swap/Free/ & Brand X
Transmission and Differential
Moparts Wheels / Tires
Moparts Memorabilia
Switch to Flat Mode
View Profile
Send Private Message
Follow User
Show Forum Posts
Default Style
infopop2
moparts
RealmHQ
sd.DarkDoom
ubbcentral.classic
UBBT77
ubbthreads
ubbthreads-dark
ubbthreads-light
ubbthreads L Type
Privacy Policy
Forum Rules
Mark All Read
Contact Us
Moparts
Moparts Main Index
| READ -
Info & Help Page
Moparts Sponsors
Tech Archive
