No NAME oil filter, I always change the oil and filter after breaking in the cam and cut the oil filter apart to inspect the pleats in the filter, I suggest you do that to the filter now and maybe remove the drain plug and use the oil dipstick or some other thin narrow piece of steel or aluminum to check how close the oil pickup is to the bottom of the oil pan, if it fits in on the thin side and not sideways on the wide side your good
If it fits in on the wide side that is to far away according to the drag race engineers at the old Mopar drag seminars
What color is the spring in the bypass your using now?
