I'm not sure why, but the torque convertor bolts are hitting the lower transmission dust shield. It appears the flexplate is on correctly, so I am having trouble understanding what is causing this. It only happens when you rev it up a bit, not at idle.
The convertor is aftermarket 10 inch unit that matched up correctly to one of my flexplates.
Anyone ever experience this or got an idea what is going on here?
