OK, after looking at the initial numbers, I was pretty impressed. However, I went back and dug through the archives and found all the "ported" and "as cast" flow numbers I could, and those Magnums stack up very well. I was very impressed when I saw the ported 915 #s:
Lift Int/Exh
.100 61.9/58.4
.200 134.3/115.2
.300 190.2/141.4
.400 233.4/157.8
.500 258.9/172.3
.550 267.9/175.5
.600 273.9/181.9
Comparing the Magnums to these, the Magnums were very close, and the Magnum R/T's with the 2.02 valves should theoretically outflow the 915's. Now THAT would be pretty impressive.
"Although prepared for martyrdom, I preferred that it be postponed."
Sir Winston Churchill
