Originally Posted by gygeneral
Ok thanks evryone, I think i'm going to try it, just ordered that one piece tray.
Jegs says for use with a flat pan rail like a fabricated pan would have. Here is a picture of the gasket/tray and a picture of a typical stock type stamped steel pan rail. Good luck with that. Maybe you could fill the stiffening beads in the pan rails with epoxy so that the ribs in the gasket would have something to seal against.
In theory, there is no difference between theory and practice. In practice, there is.
