The center castings are very different, the light ones are cars, the small ford one you have now, mid 70s-early 80s dodge vans and pickups. If it is a heavy duty pickup or maxivan, or camper special it will have the big housing. Some later housings 90s and up have the pinion moved. Check with Cass, that s60 housing is a bargain, and makes gear setup a joy
