Originally Posted by A12
feets I don't know if your carb has a black plastic cap, cover or screw on the left top side of the carb (white arrows area) that will have that vent passage when removed? That's what causes symptoms as you describe when it gets even a little blocked. If it does cleaning it with some carb cleaner and air pressure and best with an ultrasonic parts cleaner should fix it............ luck Sure sounds like a float bowl venting issue to me as the float bowl holds about 1-2 minutes of running time fuel.......or less.
That sounds like it might be the issue.
Thanks!
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
