Sometimes the vent in the gas cap plugs up and it starves for fuel. Take the cap off and see if it runs longer than two minutes.
This and the only thing you really changed is the fuel filter. It may be staving the bowl. Also clean the carb again with some compressed air and carb cleaner. Did you change any of the air bleed screw settings?
