I have seen the upper door bolsters both front and rear. The ones I saw were white '69's. Compared to what we had in the past from Just Dashes and Laysons, these rock !!!!
I'll eventually be getting a set for my '68 Charger R/T..
Make sure you save the rears because you'll have to transplant the window felts. Just undo the staples that hold the originals together and then use some very small screws to attach the felts to the new bolsters. Make sure the heads of the screw are shallow enough not to interfer with the glass while it's moved up and down. Also, a suggestion would to paint or use a black Sharpie to color the head of the screw so it blends in with the felt.
Cheers,
Troy
