Ive dealt with Mike Ross of B,E,&A body with parts for our chally convert and charger. Mike has a VERY high standard for correctness and his parts are second to none. From what I have heard (as I have not seen these door pads yet) they are not 100% but are as close as you can possibly get to originals. The ones that Just Dashes reskins lose a lot of detail. These new repro door pads that Mike has come out with have all of the tight, crips lines in them like originals do. The only slight difference is the graining which when you replace them all, will not be able to be seen unless you physically hold an original next to it.
