Originally Posted by Cab_Burge
Put the black bushing in and the lightest springs and set the total timing above 3000 RPM at 34 degrees and go have some fun up wrench twocents
You should have between 14 to 18 degrees at idle speed so it will start and idle good also scope
iagree 100%
