The pull off only needs to open the choke far enough to keep the engine from loading up. I'd start with an 1/8" drill bit held vertically against the inner choke wall. Set the pull off so the choke blade just touches the drill bit when there is vacuum applied. If it loads up open it a 1/16". If it stumbles with the choke on close up the clearance a little.
Doug
