Unless there is a real issue, a brake inspection in my world is look at the pads and verify no leaks. Done. A lot of the time it can be done without removing the wheels. Unless it has a real concern - pulling, pulsating, losing fluid, lights on, park brake hanging or something obvious - I'm not going to spend a lot of time tearing stuff apart to look at it.
The brake fluid I get. It does get nasty and degrade. However, that would be done at the same time as a brake service/pad change.
Again, I would have been done with this guy early on. I would have pushed the car off the lot before letting him do any work. Don't BS me.
I’m guessing your world doesn’t involve working on other’s vehicles, where actual safety is a concern?
