Come on guys, give me a brake! (Pun intended)
When I said car is “perfect,”.... I obviously meant in a relative sense, not absolute. No car is truly perfect, even off the showroom floor (if you want to take it that far).
“Beefy cam?” Just a quick expression. It’s been nearly 20 years and I no longer have that particular Challenger, so I forget the cam specs.
The slight right front wheel slight bass pulsing sound before stop was only noticed when driving there (two city miles), after sitting tarped d for six or so weeks. I just wanted a quick visual check of the one wheel.
As mentioned, that appears to have gone away after several more miles.
As to the repair shop issue at hand, I appreciate all the input.
My trusted mechanic shop closed (retired), so I was used to his top shelf service for many years.
All that being said, I still feel my chain was being pulled.
First clue I should have picked up on;
They wouldn’t let me wait for a simple emissions check, even by appointment.
They insisted I drop it off four several hours for their free multi-point car inspection.
