I made my own. Uses modified lower ball joints, modified original spindles, stock upper A arms, and lower control arms. I have about $300 into the entire setup, and that was buying the rack kit from Quartermax. I was able to get 5*+ caster in the car, and it drives like it's on rails. Saved a ton of weight.
