To learn a bit more about head choices for 493 to 540 STREET strokers, please post 1cubic inch 2head used 3Dyno torque down low, preferably from 2500 to 4000? 4work done on heads, compression ratio
I see the big inch engines posted so here is one a little smaller .
470 cu Edelbrock RPM heads . Port matched to RPM intake some minor port work and a comp valve job. 10.72 to one good quench.
