Originally Posted by 500ciBee
Thanks! When you say the TF intake is too small. Do you mean too small to make 750hp or to small for the 270 heads? I thought there was enough material to port the intake to the size of the intake ports on the 270.
You could use the Eddy Super Victor , works ok on my 270's
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
