Shows that if you can live with the lumpier idle, the tighter lsa(TF cam is 108lsa) helps punch up the mid-range power.
Intake manifold ootb or tweaked a little?
What did you do for a baffle for the PCV valve?
Hp/ci almost identical to your 496.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
