This this method apply tojust the stock intake or an afermarket i have a air Gap manifold??
It would apply to both as torque specs are about the particular bolt being used to get it to the right amount of stretch & the 12 ft lbs would be for the stock type bolts & not sure if the angle(vertical) affects this also.
thanks again
