Not really much to discuss here. I have a set and experienced some of the same issues mentioned. I still bought them. They are cheap. Expect them to perform cheap. This is the problem with a lot of things.....folks want the cheap to work as well as and in some instances be better than the more expensive/better quality pieces. Bottom line is if you want to push a car into a corner and leave it for a bit, these will be fine. If you are going to be moving around on a regular basis, save your money for the higher quality pieces.
Agree, cheap is cheap.
I've got 4 of the black steel ones under a road runner and can move the car around by myself once I get the wheels turned the right direction. A big ball peen hammer is my tool for that. I've turned the car completely around inside my garage on them.
Ball peen hammers and a little oil ?
Have any of you guys though about packing some grease in there ?
And I’ll be the RESIDENT EXPERT HERE after I’m done today
I’m picking up a used Hobo cherry picker and engine stand so I’m gonna fur sure try and find one of those needle greasers!
