So I got a new turn signal switch after 2 years of using hand signals. I have everything working but the hazards don't flash with the key on. I still have power to the switch, fuse and flasher but they don't flash. Turn the key off and they work. Is this normal? This truck has had a lot of backyard repairs to the harnesses, including an ammeter bypass, and I've been cleaning it up as I go but I don't want to go searching for something that is supposed to be that way. Any help would be appreciated. I have a FSM for a 77 model year but it's not here at the house. Right now I'm pretty happy to have turn signals AND brake lights.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
