Browse through some catalogs and websites for wheels, pick something affordable that grabs your attention. If you currently have wheels, double check the fitment to see if you need to make a backspacing adjustment on the new set of wheels. A-bodies have a tendency to track too wide in the front so that the front tires stick out near or past the fenders and don't look quite right, so depending on your front brakes and suspension you may need a front wheel with more backspacing such as 2 1/4".
26" tall front tire is what you want for an A-body. Any taller may rub the fender and anything shorter doesn't usually look as good.
